how do you take a fast 90mm intake apart
6600 rpm clutch dump of death Administrator
As stated, you remove all the bolts, and it will come apart. This is why it ships with the bolts holding it together.
You need to replace the seal if you take it apart. You can make a gasket out of RTV if you know what you are doing.
https://ls1tech.com/forums/generation-iii-external-engine/457355-fast-manifold-permanant-air-leak-fix.html
