GM new LSX Block 480ci?
Old 09-21-2006, 01:19 PM
SlickVert's Avatar
Default GM new LSX Block 480ci?
Does anyone have any info on the new LSX block from GM?
I saw it advertised in the latest issue of GM High-Tech, has a part # of PN 19166454 and said it is capable of 480ci for $2,500.
What is the bore size?
How deep are the cylinder?
Is this an aluminum block?
Bob
Old 09-21-2006, 02:48 PM
Banned - Ed Curtis aka EDC
LSX-Racer's Avatar
Iron now. Aluminum in about a year.
Old 09-22-2006, 08:16 PM
LS1 Tech Veteran
Steve Bryant's Avatar
What issue of GM High Tech Performance is this? I have the September issue and I didn't see this information.
Steve
Old 09-22-2006, 11:31 PM
CarolinaWS6's Avatar
i think its the november issue the one with a white SS on the cover
Old 09-23-2006, 08:49 AM
Karlo's Avatar
See Link
https://ls1tech.com/forums/generation-iv-internal-engine/549932-new-gmpp-lsx-block.html
Old 09-23-2006, 02:49 PM
LS1Tech Premium Sponsor
Trevor @ Texas Speed & Perf.'s Avatar
Theoretically speaking, there is supposed to be a 4.20" bore iron block with a 4.25" bore setup soon after. Again, this is just theoretically.
__________________
Old 09-23-2006, 03:04 PM
Wnts2Go10O's Avatar
"big" block LS1=)
Old 09-23-2006, 08:27 PM
SSilverSSurfer's Avatar
just do a 500ci like SAM
Old 09-23-2006, 08:44 PM
Tom@SpeedInc's Avatar
No disrespect for SAM, but ERL deck deal isn't for everyone. I'd expect you would need to run custom headers for higher deck height. Custom intake manifold too.
I'd be more interested in GMPP LS1 block with large bore.
Old 09-25-2006, 08:18 AM
Quick Carl's Avatar
Full length headers are probably an issue on any of the tall deck blocks unless you run shorty's. I'm not sure if they are going to put it in their F body after testing the sheet metal intake or bump the compression and cam first. That will tell about headers. The intake has spacers (in SAM's posted pictues for LS7 heads) to run any LS intake.
Old 09-25-2006, 08:32 AM
motormonkey's Avatar
I havent heard anything about the new lsx block. Does anybody know if its a priorety main or is it a vvt oil style?
Old 09-25-2006, 10:10 AM
Karlo's Avatar
By DB Z28
Originally Posted by DB Z28
Heres The Scoop That I got at the RPM Show
100% CNC Block Cast iron (280 kpa tensile)
True proirity oiling
Siamese cylinder bores
6 head bolts per cylinder
Standard 4.400 bore spacing Standerd deck height (9.700 tall deck to Follow)
Increase deck thickness
LS7 6 bolt Doweled in place Billet Main caps
Max 4.500" Stroke (tall deck only) Capable of a 364 to 500+ cid Tall deck for large displacement
Wet and dry sump capabitly
Deep Skirted Head bolt Holes
Orange power coat
Maintains all OEM LS family exterior mounting features
Accepts all Gen III & LS Heads ,cranks Cams ,ect.
Includes Unique new cam retainer,rear cover and lifter retainers and OEM cam bearings
Front Motor Plate mounting holes added
Added material above cam bearings for added strength
Approximate Finish weight 225 lbs
9.26 semi finished deck height (Standard deck height)
3.990 bore ready for honing,maximun 4.250bore @ .200 Minimum wall thickness.
6 bolt LSX bolt pattern
11mm standerd bolts 8mm exterior /interior bolts
Can be machined for 1/2 in bolts or studs
All 5 cam bores for standard small OD bearings P/N 12453169
can also be machined to 60mm roller bearings
Added material around standerd .842 lifter bore also can be machined for large lifters and/ or 1.050 bronze bushings
O-ringed screw in soft plugs
Accommodates any LS small block oil pan and oil pump, standard LS wet sump systems and LS7 dry sump systems fit.
Extermal oil pump feed @ rear of block
Front oil line can be plugged and external oil pump /aftermarket dry sump system can be used.
Belt cam drive can be accommodated.
7th tranmission bolt hole added per early sbc
Main web bay to bay breathing holes for increased HP
Access windows for cylinder head stud access (intake side)
Extra Breathing pockets added near starter for better windage
Thats it real nice sweet Coming March 2007
Old 09-25-2006, 11:09 AM
Thanks for info and i cant wait. Why are the blocks going to be orange? That will throw the whole sleeper *** handing effect out.
Quick Reply: GM new LSX Block 480ci?
