Aluminum or Iron???
The only thing that scares me with an aluminum block is you can't overbore it if, say, you drop a valve in the cylinder, or melt a piston and it scores the bore past a cleanup hone.
Originally Posted by Mean Green z28
Nope, 6.0=366ltr, 402=6.6ltr, 408=6.7ltr
iron block is good for F/I (stonger than aluminum but too havey)
aluminum is good for N/A (light weight, good for up to 700-800hp)
Originally Posted by 05 GSXR 1XXX
i was under the impression that the alum blocks where only good to 600? is this correct?
ive also heard the same thing he has just hearing it throughout the forums and stuff i just wanna make sure what i build will not screw up because i didnt build it with the right block.
by the way i know this is a duplicate thread as in the LS1 LS6 section because i wanted all opinions on motors cause i dont know which im deciding to go with yet and wanted to get everyones opinions.
