basic LS7 Balance question - LS1TECH
Thread Tools Search this Thread
Old 11-23-2006, 09:43 PM   #1
Default basic LS7 Balance question
Does anyone know at what point the crate LS7s are balanced? Is is done pre or post mounting of the 1) flywheel 2) clutch etc. So if I'm using an aftermarket flywheel and clutch, will the balance be off?
TIA.
wadd is offline   Reply With Quote
Old 11-23-2006, 10:35 PM   #2
LS1TECH Sponsor
Katech_Jason's Avatar
Quote:
TIA.
Bobweight is based on piston/rod assembly mass and crankshaft charactaristics. You can change the flywheel and it wont affect it's balance.
Katech_Jason is offline   Reply With Quote
Old 11-23-2006, 11:07 PM   #3
helicoil's Avatar
You may be catious of some aftermarket flywheel and clutch assemblies. I have seen them where they were not '0' balanced. A good machine shop can 0 balance these pieces for you or at least check them! It would be well worth the money.
helicoil is offline   Reply With Quote
Tags
balance, ls7
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
