ls2.. dry sump oil?
ls2.. dry sump oil?
i think i read somewhere that if i go with an ls7 in my truck i will have to convert to dry sump oil which will be a pain in the ***... what about if i go with the ls2? my truck is a 2000 silverado.. i'm mainly just goin for the corvette engine since its just a show truck.. so i did some thinkin and i guess it dont really matter if i do ls7 or ls2
Originally Posted by DONAIMIAN
You thought about an LS1? Hell just change the coils and intake so you can run the vette engine covers.
but if someone could tell me if the crate motor is dry sump oil or not i'd appreciate it.. i've been searchin but i guess i dont type in the right stuff
Originally Posted by Wardrum
Crate LS7 is dry sump but can be changed to wet sump. Crate LS2 is wet sump, can be changed to dry sump. IMO, both are great engines but the LS2 is less $$$$
Originally Posted by GOaT Cheese
You will have to run different PCM and wiring harness to run the LS2. But otherwise it would probably be pretty easy to do.
He wont have to change the harness or the PCM. The only things he will need are a custom tune, and the two extentions for the cam position sensor and the knock sensors.
Originally Posted by MyWs62FaST4u
why would you want to run a dry sump over the wet...
