GM LSX really how much heavier than a 6.0 iron block?
What do you guys think the weight difference is between the new 6.0 iron block and GM's new LSX block? i am sure alot of people want to know.
I used the 3.998 number this time and the 4.2 bore, using the lighter density of cast iron of .26lb/ci and a sleeve length of 6.1 inches you will remove 16.5 lbs by boring then.
It will change dependant on sleeve length, I made a conservative assumption that the piston I have for my LS2 with a 4.100 stroke and it has a 2.13 skirt, so a sleeve length of 6.1 since they are not square bottoms.
Density of cast iron ranges from 6800kg/m^3 to 7800. I used 7200. I had assumed it was more dense than steel and similar to SS that is approx .3lbs/ci in the original estimate with the smaller bore.
I don't do this stuff much anymore.
Mind you the bigger bore means bigger pistons too and likely valves so you will be putting weight back in with the actual build.
I have been watching this block closely since I really want to build a streetable 455ci motor, but weight is a concern for handling.
Originally Posted by tlaselva
If big cube's your fancy, but weight's a concern like it is for me, the Warhawk block's your ticket.
I know not a great reason to go after that displacement, but thats the way I am.
The Warhawk does look like a nice peice though.
I like the nostalgic Ram Air 455 number.
Originally Posted by BlackHawk T/A
They are talking about doing an LSX in aluminum. For the guys not running 30psi, or 1500+ HP, that will be the one to watch.
I hope you are right and that it can support the larger bores as well. That would be the ticket for sure. I won't be doing this this season the 412 has to work a little longer. For me the cheapest would be to use my rotating and the LS2 block at a 4.155 bore and 4.100 stroke but it still is not the magic 455 for me. 10ci's short.
I'm keeping an eye on that block too, but it will have more bore limitations. I will only need NA if I can get those cubes. I like the nostalgic Ram Air 455 number.
