ls1 valve covers fit ls7 heads?
Old 07-07-2007, 09:33 PM
C Murda's Avatar
Default ls1 valve covers fit ls7 heads?
will ls1 valve covers bolt up with ls7 heads? justwondering as i want a nice set of covers and no one makes any for ls7s that i know of.
Old 07-07-2007, 09:41 PM
the_merv's Avatar
They bolt up no problem, you got to remove and grind the Baffles down in the Passenger's side Head. I have L92 Heads, same thing as the LS7's when it comes to the off-set Rockers.
Old 07-07-2007, 09:43 PM
blackz97's Avatar
Heard rumors that they will do an aluminum one eventually, dont know the time frame and like i said all i heard was rumors. Maybe someone else will chime in with a more firm answer. Anyhow if you are looking for a tuff aftermarket aluminum block, World has their Warhawk block that will handle a good deal of power.
good luck with your buildup
Steve
Old 07-08-2007, 12:11 PM
C Murda's Avatar
Steve
thanks...and you guessed it, im buildin with the warhawk block.
Quick Reply: ls1 valve covers fit ls7 heads?
