L92 Heads on stock LS2 - what cam specs?
Old 07-10-2007, 10:25 PM
Robofuzz's Avatar
Default L92 Heads on stock LS2 - what cam specs?
What cam specs should I be looking at for a stock LS2 6.0 with L92 heads? The heads are stock GM Performance Parts L92 heads milled .030, and the GTO already has ARH 1 7/8 LTs with catted mids. With a 228/230 cam and the L92 heads, the GTO is putting about 405 to the wheels on a Mustang dyno, but the tuner feels that the heads are just laughing at that cam.
I tried to do a search but the search function is taking FOREVER to return results. Any help appreciated!
Old 07-11-2007, 07:12 AM
Landshark1's Avatar
Talking
http://www.ls1gto.com/forums/index.php
Old 07-11-2007, 09:43 AM
Robofuzz's Avatar
Originally Posted by Landshark1
Old 07-11-2007, 09:49 AM
speeddemongto's Avatar
You have been banned for the following reason:
Going around the autocensor
Date the ban will be lifted: 07-16-2007, 03:00 PM
LMAO
same question I have also...can the MS3 be run with L92's?
Old 07-15-2007, 12:49 AM
Chicago Crew UnderBoss's Avatar
I would call VENGEANCE and LME and give them your goals and heads being used and they should hook you up with a great cam for your given application (as they are both making big power on these motors)!
Quick Reply: L92 Heads on stock LS2 - what cam specs?
