Can't remove cam retaining plate
Old 07-08-2007, 06:17 PM
98C5LS2's Avatar
Default Can't remove cam retaining plate
I'm changing cams and the last hex bolt for the plate won't come loose. It feels like the guy that put the original motor together used Loctite because the other bolts were an bear to break loose.
Now my big problem is the inside of the hex bolt rounded out. I tried to get vice grips on the outside but because it is recessed, I can't get a god grip.
Any suggestions?
Thanks.
Old 07-09-2007, 07:46 AM
JoeyGC5's Avatar
easy out or worst case try to weld a nut on the bolt
Old 07-09-2007, 09:18 AM
97zSC's Avatar
ya, if you can get at it with a left hand drill bit and an easy out that should do the trick
Old 07-09-2007, 11:29 AM
98C5LS2's Avatar
Thanks!
Old 07-09-2007, 12:15 PM
ShiznityZ28's Avatar
Vice grips. LOL
Old 07-09-2007, 08:33 PM
98C5LS2's Avatar
Originally Posted by ShiznityZ28
Vice grips. LOL
Yea - tried it.
Old 07-10-2007, 07:39 AM
JoeyGC5's Avatar
Just take your time with it and don't try to rush it
Old 07-10-2007, 08:06 AM
LS1Tech Sponsor
Slowhawk's Avatar
put vise grips on there straight on,heat the area with a torch and it will come out easy.
Or weld a nut on it and the heat will break it free.
Old 07-11-2007, 09:40 AM
98C5LS2's Avatar
Thanks - we'll see this weekend.
Old 07-14-2007, 10:01 PM
98C5LS2's Avatar
I posted this on Gen III too:
For anyone who is interrested, I got a kit that consists of sockets that fit over the head of a rounded off bolt. THey have machined in "blades" that are similar to rifling in a gun barrel. They fit snug on the bolt (lightly tapped with a hammer) then put a ratchet on it and loosen. It digs in as you loosen. It came right out effortlessly. Best $20 I ever spend. Also purchased the correct bolts from the dealer.
Quick Reply: Can't remove cam retaining plate
