LS7 double roller?
LS7 double roller?
I'm building my engine using an LQ4 block, but I'm running an LS7 dry sump pan and pump, so I'm not really sure what I need to do for a timing set. Should I run a stock LS7 setup or is there a double roller to use instead? Can I run the 12588670 dampener if I run a stock timing set?
Thanks for any insight/help you can provide.
