Head gasket options for LS7 heads???
Old 07-15-2007, 06:48 AM
SideStep's Avatar
Default Head gasket options for LS7 heads???
What are the head gasket options for LS7 heads??? (bore dia, compressed thickness??)
Old 07-15-2007, 07:18 AM
Haans249's Avatar
You can go stock, or check out cometic. Thats what I'm using, and they're very nice, and seal very well... http://www.cometic.com/domesticauto.aspx
Old 07-15-2007, 08:25 AM
SideStep's Avatar
What thickness/bore are you using???
Old 07-15-2007, 01:02 PM
Haans249's Avatar
I'm using one with 4.16" bore, and .051 thickness only because my pistons are out the hole +.018. I'm going to get my heads milled, and run a 4.13" bore gasket at .051 thickness to get me to 12.0:1 for my engine.
Best Regards,
Adrian Mejia
Old 07-15-2007, 01:11 PM
Ferocity02's Avatar
I used the same exact ones, 4.160" bore from Cometic. They worked great!
Old 07-15-2007, 03:15 PM
SideStep's Avatar
4.160"
Why so large???
I figured everyone (at least the 4.125 bore crowd) was using 4.130...
Old 07-15-2007, 08:01 PM
VortechC5's Avatar
I am using stock LS7 gaskets. If I remember correctly Brian at SPDC told me that tey are .060 thick.
Old 07-15-2007, 09:18 PM
427cidLT5's Avatar
Side Step... Flatout Gaskets makes a mls gasket for the LS7 also...I think they will also do rubber coated copper in whatever thickness you want.
Old 07-15-2007, 11:16 PM
Tom@SpeedInc's Avatar
4.160"
Why so large???
You want expansion room for the gasket, and for firing ring to be within size of the combustion chamber. OE LS7 MLS gasket is 4.150"
Old 07-16-2007, 07:10 AM
Haans249's Avatar
Thanks for the good explanation =D Everyone learns something new everyday.
Best Regards,
Adrian Mejia
Old 07-16-2007, 11:50 AM
Ferocity02's Avatar
4.160" bore is not THAT big. Best to go with some that are a little larger than too small. The extra volume they have is neglidible. I'd actually go with some LS7 gaskets since they are pretty cheap and work well. They were on backorder when I built my engine.
Old 07-16-2007, 03:29 PM
gun5l1ng3r's Avatar
What kind of NA compression can the stock gaskets hold?
Would they be ok on a 14:1 or 15:1 High Compression Race Motor?
I am thinking along the lines of LS7R here...(I have to ask after seeing the LS7R at Chevy's RevItUP driving event)
EDIT: Off topic, but that LS7R had Katech stuff ALL over it. Heads, valley cover, some weird looking coil set-up for the spark plugs(two black boxes instead of 8 coils), dry sump, it was fraking sweet to finally see some Katech products in person...
They also started the C6R they brought with them, but I was told it had just an open exhaust LS2 with some sort of cam. It sounded high compression though...
Back on topic>
Quick Reply: Head gasket options for LS7 heads???
