et ls7 head availability?
Old 07-18-2007, 06:17 PM
Greg Fell's Avatar
Default et ls7 head availability?
does anybody know who, if anyone, has a set of either the 4.1 or 4.0" version?
Old 07-18-2007, 07:52 PM
Michael4034's Avatar
I have a set.
Old 07-18-2007, 08:11 PM
10 Second Truck Club
67SS509's Avatar
Just got mine last week. They are the 4.1+ version. Took 9 weeks to get them. Mine have the coated 2.20" Ti valves and I guess that added some extra time to the delivery. They were also machined for the Jessel rockers.
Old 07-18-2007, 08:17 PM
7 Second Club
Phil99vette's Avatar
What did they do to the heads for the Jesel Rockers? AFAIK the Jesel LS7 rockers are an single stand like the factory LS1 but one rocker per truition. I had one set about 4 weeks ago but they made a mistake when they did the cup adjuster vs the ball adjuster. My new ones should be here friday.
Old 07-18-2007, 08:49 PM
67SS509's Avatar
They had to machine the head down where the single stand sits and clearance the rails for the rockers. I still had to hand grind some for the rockers at the rails. Another problem I realize now is that the raised rails are a mistake with the Jessel rockers. When you use a spacer rail to raise the valvecovers you can set them on the head and see + mark where to grind them. With the raised rail and set the valve cover on you can't see where they are hitting and how much to grind off. If I can find somewhere local I'm going to take my rails down to stock height.
Old 07-18-2007, 09:46 PM
427's Avatar
When you cut the rails down, it helps if you angle mill the head on top. It angles the valvecover away from the backside of the rockers. If you do this, you need to plug the original valve cover bolts and re-drill when your set up on the angle.
Kurt
Old 07-19-2007, 07:52 AM
67SS509's Avatar
Kurt
I had not thought of that. That's a great idea!
Old 07-19-2007, 09:54 AM
Greg Fell's Avatar
Originally Posted by Michael4034
I have a set.
for sale? or for your use?
