LSX 455 w/ Warhawk Dyno numbers
Old 07-25-2007, 09:36 AM
regal's Avatar
Default LSX 455 w/ Warhawk Dyno numbers
Through a Th-400 with a loose stall and a 12 bolt
RWHP= 504.60
RWTQ= 676.81
regal is offline
Old 07-25-2007, 09:52 AM
11 Bravo's Avatar
Any numbers with a locked stall?
11 Bravo is offline
Old 07-25-2007, 10:33 AM
walker94z28's Avatar
RWHP= 504.60
RWTQ= 676.81
NICE........
walker94z28 is offline
Old 07-25-2007, 10:56 AM
edcmat-l1's Avatar
How you gonna lock a turbo 400 converter?
edcmat-l1 is offline
Old 07-25-2007, 10:58 AM
edcmat-l1's Avatar
RWHP= 504.60
RWTQ= 676.81
How bout a graph? Sounds like the TQ number is a spike from the 'verter flashing.
Old 07-25-2007, 11:10 AM
BMW ///M Nerd
BAD ASS TA WS6's Avatar
I'd love to see a graph as well. Any details to share on the motor?
BAD ASS TA WS6 is offline
Old 07-25-2007, 11:46 AM
regal's Avatar
I will try to post the graph a little later, the motor is a 455 Lsx with warhawk ls7x heads and a large hydraulic roller. Gm ls7 carb intake with elbow. Kooks headers, TH-400 and 12 bolt. Warhawk ls7x heads , modified for all 6 bolts on the block and ported for over 400cfm on intake side
regal is offline
Old 07-25-2007, 11:53 AM
Race your car!
JL ws-6's Avatar
Damn that's making some good power! That in a 3400 lb car shoudl easily be able run run somehwere in the 9's providing the suspension works decently, congrats!
JL ws-6 is offline
Old 07-25-2007, 12:12 PM
98 TA's Avatar
I was thinking the same thing.
I was thinking not. Seems kinda low for such big cubes.
98 TA is offline
Old 07-25-2007, 12:18 PM
edcmat-l1's Avatar
yep.....
Could be the converter soakin it up. Still seems low tho.......
Old 07-25-2007, 01:01 PM
Race your car!
JL ws-6's Avatar
I can relate to the setup this is probably running, my car also has a n/a converter and th400, made 470 rwhp. A more streetable compression/cam setup to what I am runnign made 505 thru a stick car...
the tq is a spike on the dyno, but trust me, anything that spikes that high is gonna run like a **** at the track, obviously what the guy's worried about with that tranny/converter setup.
JL ws-6 is offline
Old 07-25-2007, 02:15 PM
regal's Avatar
Yep, ask anyone on here running a th-400 and they will tell you it eats a ton of power. The car is full weight 3950 and ran a best of a 10.006 on the old motor. car still has a/c , p/s and all the other ammenities
regal is offline
Old 07-25-2007, 02:30 PM
98 TA's Avatar
In reality, dyno numbers mean nothing. I care more about track times. If your car went 10.09 ET with a 39XX raceweight, that's incredible. Not sure what differs from the old motor to the new, but if its any better, you're definitely in the 9s.
But yes, a 12 bolt, slicks, steel driveshaft, 3 speed, big gear, and a loose unlocked converter will eat up A LOT of HP.
98 TA is offline
Old 07-25-2007, 02:48 PM
regal's Avatar
well the old motor was a 408, and through the th-400 we were right over 400 hp, so this motor is well over the old setup and should run good for us
regal is offline
Old 07-25-2007, 03:19 PM
deadpool0907's Avatar
will you spray this motor or just run it n/a?
deadpool0907 is offline
Old 07-25-2007, 03:41 PM
edcmat-l1's Avatar
Yeah, the converter more than anything soaks up the HP. All of it combined, though, really adds up.
Old 07-25-2007, 04:26 PM
NemeSS's Avatar
when/where will the car be run?
i wouldnt mind checking out
NemeSS is offline
Old 07-25-2007, 10:01 PM
GOaT Cheese's Avatar
Th400 takes roughly 75 h.p. to run, add accordingly for slippery converters, until they couple of corse.
GOaT Cheese is offline
Old 07-26-2007, 04:43 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
What stall speed?
Beaflag VonRathburg is offline
Old 07-26-2007, 04:56 PM
edcmat-l1's Avatar
Where do you come up with these numbers? 75 HP is an *** load of power. You using a trans dyno for comparison numbers? Or just pulling numbers out of your ***?
If you're trying to compare trans to trans, you cant do any type of comparison without locking the converters in both types of trans, and then measuring the power loss.
I wouldnt think a th400 would absorb any where near that much power.
The stall is what will act like the sponge.
Quick Reply: LSX 455 w/ Warhawk Dyno numbers
