alum lsx block?
Old 07-29-2007, 04:40 PM
Greg Fell's Avatar
Default alum lsx block?
anyone know if the general plans on making one?
Old 07-29-2007, 11:59 PM
Bader-X's Avatar
what`s the use of it? already there is a L92 4.060 bore and the ls7 with a 4.125 Bore that is enough in my opinion for my uses that is if I`m going aluminum .... maybe you want a 4.200 and above bore with a raised deck that can have a 4.500 stroke?
what`s on your mind? what`s the specs on your mind since the bore of an aluminum block has limited increasing ability?
Old 07-30-2007, 12:21 AM
Phoenix 5.7's Avatar
even if GM doesn't, there is the World Products Warhawk. its AL, has all sorts of special features and stuff.
Old 07-30-2007, 11:49 AM
Bill00Formula's Avatar
I was wondering as well. Also the related lsx ls7 heads.
Old 07-30-2007, 11:51 AM
Ferocity02's Avatar
Who makes a 4.500" stroke crank? Anyone built a 511ci engine from the LSx yet?
Old 07-30-2007, 11:53 AM
Stang's Bane's Avatar
I don't think the tall deck version of the block is available yet.
Crank would more than likely be a custom piece at first, then as more blocks become available, someone will make a shelf piece.
Old 07-30-2007, 12:34 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
The largest crank I've seen is the eagle 4.200.
Old 07-30-2007, 02:04 PM
Ferocity02's Avatar
I've seen a 4.250 stroke crank, I don't know who made it though, Lunati maybe. I guess you would have to go custom at this point or try to offset grind a crank.
Old 07-30-2007, 03:20 PM
Bader-X's Avatar
http://www.eaglerod.com/products/Che...%20cranks.html
4.250 stroke crank off the shelf.
Old 07-30-2007, 03:41 PM
Collections Removal
MerlinPro's Avatar
4.500 Stroke, Callies # APQ34V-MG, sitting on our shelf for our 9.8 deck 481.
Old 07-30-2007, 04:26 PM
OWN3D BY MY PROF!
Originally Posted by Bader-X
That's what it was. I knew eagle made it I just didn't want to look it up.
That sounds like it's going to be quite the torque monster!
Old 09-23-2007, 11:52 PM
Greg Fell's Avatar
any updates?
Old 09-24-2007, 09:13 AM
LS1Tech Sponsor
Robin L's Avatar
Here is the list in order of priority as I know it. It could change so don't yell at me if it changes
Tall Deck Iron Block by the end of the year.
LSX 6 Bolt heads
Aluminum Version of the current LSX Iron Block.
No I don't know if there are any plans for a tall deck Aluminum.
Robin
Old 09-24-2007, 10:35 AM
texada's Avatar
LSX 6 Bolt heads
Robin
What abou the LSX 454 crate engine, any prices yet?
Old 09-24-2007, 10:38 AM
LSX 6 Bolt heads
Robin
VEry interested in the LSX heads, preferably as cast......
Old 09-24-2007, 10:39 AM
Greg Fell's Avatar
are they lsx heads much different than the ls7 heads, in terms of ports/flow/valves size?
Old 09-24-2007, 11:37 AM
OWN3D BY MY PROF!
That's good to know that it's at least planned on being built.
Old 09-24-2007, 11:50 AM
Greg Fell's Avatar
yeah, would just be nice to know 'when' and how much (ballpark)
Old 09-24-2007, 02:07 PM
GrnDragon's Avatar
This just seems strange that they would offer the LSx in Aluminum, when the LS7 block "could" easily be near the strength of the Warhawk or anything they make if it had better sleeves. It already has billet mains and large bore, the only down fall is the sleeves, but hey I don't think I will ever understand the general. I'm not going to complain with another option though, especially if it is less than the Warhawk.
Old 09-24-2007, 02:12 PM
Greg Fell's Avatar
there are other nice things the lsx offers, 4.250 bore with .100 thickness still, priority main oiling, etc
