4.200 head gasket for LSX Block
Currently, I've been told that the largest bore you can run on a LSX block is a 4.185 due to no one making a head gasket larger than this bore size. Is someone in the process of making a head gasket with 4.200 & 4.250 bores? I am sure other people would like to know this as well.
LS1TECH & Trucks Sponsor
Cutting a gasket with a big bore is not difficult. However, when you have 4.40" bore spacing, you literally run out of room between cylinders with a gasket cut that large. Simple math: 4.40-4.20 =0.20" of gasket to seal between cylinders. You might as well seal it off with a bead of RTV silicone and hope for the best!
IMO, GM screwed up a bit when they advertised a max bore of 4.250" on these blocks. Although it sounds like alot of fun, you run into more issues than it's worth in the end.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Cometic has a 4.210" which is the biggest you would want to go anyway. But I woudn't consider anything bigger then a 4.185" bore for long term issues.
Like Matt said..why GM claims 4.250" bore is odd.
If GM screwed up in advertising a max bore of 4.250" on a 4.40" bore spacing, what then are we to make of claims that Darton dry sleeves can handle a 4.190" bore and that MID sleeves can handle a 4.200" bore?
