What heads for my 422???
like the title says...im pretty sure im gonna go with a 422 instead of a 408...what heads should i get...better yet ...im not too knowledgeable when it comes to stroker cams ....so which cam AND heads should i get??
GM L92 422
Eagle 4.0" crankshaft
Clevitte H-Series Bearings
Eagle 6.125 connecting rods
Diamond 4.100 Forged Pistons
File to fit Total Seal Piston Rings
Clevitte H Series Rod and Main Bearings
GM L92 422
I see you are in Houston. Greg Good is a very good head porter from Houston and a member here, I would talk to him about your plans and budget.
If you want an off-the-shelf setup, I would look at TF235, AFR 225 or ETP 240 w/ a ported Fast 90/90.
As far as a cam : Cam Motion 246/250 .632/.628 113+3 or 253/257 113+3, with the above heads and 11.5 to 12.0/1 cr will make 550 rwhp/low 500 rwtq.
I've got 853 factory castings Stage 3 ported by MTI and I made 547/513 thru an automatic with the 246/250 Cam Motion on a 116 lsa. A few more cubes is all.
Originally Posted by 94 guy
gtovan, what about out of the box L92's how much rwhp? and would you suggest cam motion for that?
