LS7 Crank
factory bob weight is set at 15XX grams from the factory. If you are at or below that it shouldn;t be a problem. if heavier, your machaine shop can just take out some of the mallory and add a touch more to balance it out.
FWIW, katechs pistonson stock LS7 rods 4.125 bore is under that at 1450 grams.
