CAM advice -224/232
Old 08-17-2007, 05:50 PM
miji_am's Avatar
Default CAM advice -224/232
hey guys
ive posted a thread before but im still concerned about that cam and if its for Daiy Driving or strip only checkout the specs and give me your oppinions
Speed Inc Blower Street Grinds 346-408ci
Cam Duration Lift LSA
int. exh. int. exh.
SC1 224 232 .581 .595 114
btw will it fit and whats with the blower stroker grind sh***t
i dont understand what they mean.
thanks in advance appriciate it
miji .....
Old 08-17-2007, 07:17 PM
JPH
JPH's Avatar
it will work, but not the most optimized cam for your mods/goals IMO.
Old 08-17-2007, 07:52 PM
carado1984's Avatar
Originally Posted by miji_am
hey guys
int. exh. int. exh.
miji .....
Well i believe that cam is suppose to make power more in the mid to higher rpms and help get some of that forced air out of the engine. If i was you i wouldnt get a blower cam for a NA engine just because youre leaving some power out. This is meant more as a cam to add a little power to a blown engine where the blower is making most of the power.. You generally wont find as big of a split on a non blower cam with similar duration and probably a lower LSA would be in order for something like that small.. Maybe a 224/228 similar lift on a 112, if youre looking for something that small. If you want a good daily driver (keeping in mind that a tune plays a big part) that also makes some power look for something in the low to mid 23X with a little more lift, around 600-610 on a 112.
Old 08-21-2007, 11:45 PM
Chicago Crew UnderBoss's Avatar
hey guys
int. exh. int. exh.
miji .....
I am no Predator Z cam guru but am of the opinion that this is a very nice cam for street/strip duty on a N/A stock cubed motor and perfert for a stock cubed cent supercharged motor. The 114lsa will give you a great idle and make this very streetable and it will have a slightly higher rpm band with the 114 lsa vs a 112lsa. Also, the lift is more than adequate without being overly agressive and too tuff on your valvetrain. With today's standard of big stock cubed LS cams this certainly does not fall in that category and is more in the middle as far as overall size and agressiveness. Put a procharger on that baby and really enjoy it or stay N/A and it will work very well!
Old 08-22-2007, 12:06 AM
Tom@SpeedInc's Avatar
hey guys
int. exh. int. exh.
miji .....
Salam
need to know what you have planned for torque converter and rear end ratio?
you can PM me if you like.
Old 08-22-2007, 01:07 AM
eLTwerker's Avatar
looks similar(exhaust lobe that is) to some of the futral grinds. I would suggest the f12 or f13.
http://www.futralmotorsports.com/fms....asp?pf=1&pg=5
Quick Reply: CAM advice -224/232
