04' Sierra 416ci L92
Considering my first LS motor build. Are the motor mount holes on the new L92 block the same as the LQ4 block? Will the new motor bolt right in place of the old motor? Also, can you use the stock truck L92 intake in an 04 truck with the original wire harness? Throttle by wire the same? Map, knock sensors interchagable?
LS1 Tech Veteran
I think the answers to all of your questions are yes. However, they are better asked over on the sister website performance-trucks.net in the internal engine forum .http://www.performancetrucks.net/for...play.php?f=158.
All my best,
Steve
All my best,
Steve
