cam is a 227/236 .600/.600 114LSA will it idle close to stock?
Old 08-28-2007, 06:11 PM
showdown's Avatar
Default cam is a 227/236 .600/.600 114LSA will it idle close to stock?
Will this pass CA smog
LS2 block
Callies rods
Wiseco pistons (right around -28cc dish)
Callies crank (no need for a HIGH DOLLAR crank)
AFR 225 64cc heads (or something with a THICK deck)
8.9-9.0:1cr
clevite bearings
LS6 lifters
Comp 921 springs
Comp pushrods
Cometic .051 MLS gaskets
ECS 8" crank pulley
ARP main and rod studs
ARP head studs (Unless stock deck. Then ARP L19 studs)
Stock 1.7 rockers (no need for rollers, DONT go 1.8's)
Old 08-28-2007, 06:18 PM
speeddemongto's Avatar
damn CA smog *****
Old 08-29-2007, 09:20 AM
gtovan's Avatar
No it won't idle anywhere near stock. As far as passing Cali smog test, I seem to remember that you need to stay around -5 degrees overlap @ .050, so something like a 224/226 115 would be more likely to pass.
Old 08-29-2007, 10:09 AM
Jeff@TotalPerformanceEng's Avatar
This is my EXACT cam.. My car idles VERY VERY well. When I had my cam spec'd by LME and Cam Motion, I was incistant that the cam idle close to stock, with an extremely mild lope.. I couldnt be happier..
I'm not sure about CA smog laws, but my car passed the sniffer on its first try with no tricks..
Old 08-29-2007, 05:41 PM
showdown's Avatar
Jeff, this is the build that you gave me on Corvette Forum. This seems like a super reliable setup if I do it right. I know that the LS7 cam will pass, but what would I be giving up in the HP/tq department? any guesses, Anyone?
Old 08-29-2007, 06:44 PM
Billiumss's Avatar
Short answer, NO.
You will have to much valve overlap and will fail emissions.
Old 08-31-2007, 04:23 PM
showdown's Avatar
How much would I lose by going with the LS7 cam? It is smog legal.
Originally Posted by Billiumss
Short answer, NO.
Old 08-31-2007, 07:08 PM
LS1curious's Avatar
NO it will not.
LS2 block
Callies rods
8.9-9.0:1cr
clevite bearings
LS6 lifters
Comp 921 springs
Comp pushrods
ECS 8" crank pulley
Quick Reply: cam is a 227/236 .600/.600 114LSA will it idle close to stock?
