Building a 6.0L stroker 408 i have questions
i will be running a turbo 350 can i use a ls1 flexplate or does it have to be a 6.0l flexplate? on the eagle crank and rods does the 6.0 need clearancing if so where?
1 Post
you'll need a TCI flex plate. Some people say a 98 model flexplate will work, but in the end you still have a stock flexplate. TCI is alot stronger.
You dont have to clearance anything in the block.
