LSX Deck Height Questions and More
I can't seem to get straight answers on if the taller deckheight decks are available or not, or what deckheight is the one (single partnumbeR) in the GMPP catalog? Also, if there is a taller deckheight, is anyone making off the shelf parts for these yet that are boost friendly? If there is two deckheight blocks and both available please share the part #'s... with a taller deckheight block will i still be able to run a stock intake mani or is the angle then too far? forsee any problems physically fitting the motor in a c5 vette?
For those that have ordered the blocks, how long was the wait, and is the rumor true that they require $1000's of machining just to be cleaned up and milled because they come like run of the mill crate motors? I assummed they were bad *** and came line honed/etc out of the box and you could just punch em out and be done..
Thanks!
Thanks!
email or ring sdpc-they were saying their is a wait or the wait is over and they are in stock-
They are very helpful and will provide u with all the deck height numbers-
i dont know about the $1000's of maching from what i understand they come good as gold out of the box with the 3.890 or 3.900 bore size-
so in a sense it would cost money if u decide to go to 4.125 bore but thats your choice-and also common when modifying-
warhawk is out also-dont know if they offer a tall deck block-i think they do-do a search on that too-
also i would say they are very boost freindly depending what bore or stroke size etc etc-(cast iron would help more than alloy in fi applications)
they claim to be good or tested to 2500 hp- they are strong but weight more than alloy of cousre-
so with a example of 2500 hp-i dont think weight would would be my issue if u could even get that kind of hp out-
max size bore on standard deck height is 4.250-thats all i know.
Hope that helps a little-
Lowest 09.2599
Position Bank1 Deck Bank2 Deck
Front 1 09.2599 09.2611
Front 2 09.2612 09.2630
Mid 1 09.2607 09.2611
Mid 2 09.2616 09.2621
Rear 1 09.2615 09.2618
Rear 2 09.2633 09.2641
Wheel to Wheel #360
This is a deck height sheet before cutting on the LSX.
Kurt
Wheel to Wheel #360
Kurt
LS1Tech Sponsor
Originally Posted by performance fast
The LSX tall deck is not out yet. Not sure when. If Robin L. sees this post he may have a better idea.
I have heard they have several for engineering.
I'll ask again.
Robin
Originally Posted by 427
Lowest 09.2599
Wheel to Wheel #360
Kurt
Wheel to Wheel #360
Kurt
very nice of u to post this info-
Thankyou-
so if i order one with the current gmpp aprt number it will be about stock deck height? who's making off the shelf stuff now, and how big do you guys recommend i go bore/stroke for a turbocharged car with l92 heads?
LS1Tech Sponsor
OK from what I was told they were looking at an October date. But I have also heard from another source that they will not be out until the end of the year.
I will continue to try to get a firm release date.
Thanks
Robin
