Will LS1 parts go on an LSX block?
I am looking at getting an LSX 440 for my daily driver 02 Z06. Do I need all the cross over covers and wireing for the LSX like I would for an LS2? It seems to only come with a front cover and cam plate. Will my valley pan, rear cover, oil pan and knock sensors go on the new block? If I have to buy a $400 dollor package I may be forced to go with an L92 block to keep the cost down. I am looking to make 600rw NA then add a 250 shot. Does any one know for sure what the block comes with and what will cross over.
Brett
Brett
Brett
Brett
Thanks. I have ARP head bolts due to the fact I have an 05 LS6 block. I also have ARP main fasteners. Can I use those as well? Can I make my own extensions to the knock sensors and use the ones I have? I noticed your put gears with the front cover. Does this mean my Roll master double adjustable won't fit under the LS2 timing cover? Does the block come with all the oil and coolant plugs with it? Sorry for all the questions. I am just sick of buying things twice and going way over budget. I am trying to get all my research done before I spend a penny. I also checked out your motor earlier. That thing is going to be sick. If I can do 600rw with a cam in the 240's-250's I will be estatic. Thanks again.
Brett
Brett
Brett
Brett
Yes the block comes with everything else you will need but 2 flat allenhead bolts for the cam plate the ones they give you will not clear the cam gear.
Thanks guys. It looks like I will just save up some more money and do it right the first time. Is anyone selling the engine block as a complete package, i.e. with all the covers and sensors? If not, I can get all this stuff from my local Chevy dealership correct.
Chevpower. I noticed in your other thread you were running Diamond 4.185" pistons. Are those an off the shelf item? If so, what is the cc dish?
