rwhp gain after break in?
will a built 402 pick up any rwhp once it gets some miles on it. i wasnt pleased with my numbers but it only had 100 miles on it. air/fuel is dead on. its a tsp longblock fast intake full exhaust...bla blah. my midrange power is way up over the ls1 but peak was only 465"dynojet . its a automatic c5 vette. i was expectn a bit more
"back in the day.." you would have picked up some power because of the rings seating in, but with modern rings and bore finishes you might see 5hp - mostly from the wash-off of assembly lube after the first oil change.
When I breakin a motor we heat cycle the springs two times and let totally cool off. After that I drive it normal,but getting on it all the way to the redline a few times each gear with in the first 100mi. Threat it like a woman....be too good to it and it will dump on you. Threat it rough and it will keep giving you all she has.
my cam sensor wires were backwards on the new harness. i fixed that and it gained atleast 10 hp thru the entire powerband. i was getting a p0343. that was 1000 miles ago. now im still getn a random p0341. it happens during odd rpm changes. then it later clears itself. i left alabama in it sunday nite movin to las vegas. wish me luck
