390CFM PRC LS7 CNC Ported Heads Now Available!
Old 10-05-2007, 05:23 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Default 390CFM PRC LS7 CNC Ported Heads Now Available!
Guys we're proud to announce after months of development & testing that the all new PRC LS7 cnc cylinder head is complete! The PRC LS7 cylinder head was built for big cube ls engines wanting the maximum possible cylinder head flow for the dollar! With 390+cfm air flow capability this all new cylinder head is set to be the leading head choice for these new big cube LSx & LS7 based engines.
Extensive valve testing has resulted in an all new hollow stem valve option to help keep both price & valve weight down! No longer will it take $3000 to build a LS7 based cylinder head for your big cube project!
Current price on the base PRC LS-7 Cylinder Head is $1699.99 with standard stainless REV valves & stock LS1 springs. Upgrade to the all new PRC hollow stem valves & PRC double spring kit & the complete cylinder head kit is only $2199.99!
Here's the options available with these cylinder heads:
Stainless Valves / Titanium Valves / Hollow Stem Valves
Standard Spring / 928 Comp Springs / PRC Dual Spring Kit
Here's Flow data for you guys!
LS7 Int LS7 Ex PRC LS7 Int PRC LS7 Ex
cfm cfm cfm cfm
.200 161 114 168 119
.300 227 171 244 179
.400 291 193 304 207
.500 330 203 345 219
.600 351 209 375 229
.700 359 390
Check out additional pics & info @ http://texas-speed.com/shop/item.asp...d=823&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 10-05-2007, 06:19 PM
TurboLark's Avatar
Is there an intake made that will allow the head to flow that?
Old 10-05-2007, 06:23 PM
njc.corp's Avatar
thats the ****-
Old 10-05-2007, 06:48 PM
1bigcam's Avatar
will it work on a 416
Old 10-05-2007, 08:16 PM
Hennytime's Avatar
will these ever be offered with 6 bolts per cylinder so we can use them with lsx block?
Old 10-05-2007, 10:52 PM
venom ws7's Avatar
WOW Thats great price for those heads.
Awesome work Jason and Everyone at TSP and PRC.
Old 10-05-2007, 11:34 PM
1999vetteroo's Avatar
Jason,
You guys will guys will be hearing from me soon! Great job.....
Titus
Old 10-06-2007, 07:18 AM
WizeAss's Avatar
not really....the only advantage is you can run the LS7 manifold.
Old 10-06-2007, 09:39 AM
71CamaroLS1's Avatar
Would these be considered too big for a mid-level 427 build?
Any dyno results yet?
What's the chamber volume?
Can you use stock LS7 valves with these?
TIA ...
Old 10-06-2007, 01:58 PM
texada's Avatar
I know what heads I'll be using if I build a 454ci LSX. Thanks TSP
Old 10-06-2007, 02:02 PM
Bo White's Avatar
Theres no way you coulda told Grumpy Jenkins 30 years ago we could do this on a "small block" production casting
Old 10-06-2007, 04:46 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Wow, that is amazing! How much do the different valve options weigh?
Old 10-06-2007, 10:03 PM
HotWhipT/A's Avatar
Would these work really good on a 402 from you guys?
Old 10-06-2007, 11:10 PM
Thanks for all the support guys! I'll get more info for you all very shortly! This cylinder head really needs to be on a 4.100" bore. I'll have dyno results on a LS7 C6 very soon
__________________
Jason
2005 Twin Turbo C6
You can run ls7 valves
Weight & dyno results coming very soon
__________________
Jason
2005 Twin Turbo C6
Old 10-07-2007, 07:40 PM
jermzz's Avatar
Looks like they flow a little better then the etps for half the price.
Old 10-07-2007, 07:46 PM
Hennytime's Avatar
but will they have 6 bolts? thats my big thing
Old 10-07-2007, 08:18 PM
52172's Avatar
what castings are these stock ls7 or l92 I would imagine l92 so you should not call them ls7 heads. How can you use stock ls1 springs with the huge valves that must be a misprint? You would get valve float at 3000 rpms. Thanks!
Old 10-07-2007, 08:20 PM
52172's Avatar
these must be l92 heads so they have factory 15 deg valve angles right? Ls7 is misleading.
Old 10-07-2007, 09:30 PM
cncbird's Avatar
wepb site says " all new LS7 castings" -- not L92 based
Quick Reply: 390CFM PRC LS7 CNC Ported Heads Now Available!
