LSX cylinder wall length?
Tin Foil Hat Wearin' Fool
I know the iron 6.0 block has a shorter length then the LS2 block, Im wondering if the cylinder wall is longer on the LSX block then the 6.0 or the LS2 block, Im trying to fight bad piston rock at BDC with my 4.1" crank. I have gotten mixed reports on cylinder wall length on the LSx block. I hope one of my sources are wrong the LSX is longer then the iron 6.0 block.
I've read about this and have questions , too . Something about the standard deck LSX not allowing 3 rings after a certain stroke , due to piston pin height . Does this mean my 511 will never happen ?
So how are the motors with 4.1 and 4.125 stroke cranks lasting and not burning oil? I have had two different sets of pistons in my iron 6.0L block with my 4.1 stroke crank and both burn oil. The first motor burnt oil to the tune of 1 quart every 80 miles, the second motor burns a quart every 200ish miles. First set was JE's second set are wiseco's. Im running a 6.125 rod, is there something Im missing here?
I think he means the same as the iron blocks because I have heard the LSX and the 6.0 iron block have the same length cylinders. The LS2 block has a .2" longer sleeve.
All the stock OEM cylinders on LS1 type engines (including iron 6.0 and LS1, LS2, L92 etc.) are only 5.500-ish besides the LS7 which is much longer at 5.900-ish.
Most people aren't measuring the cylinders correctly and the LS2 has aluminum casting that goes further down but the cylinders are still as short as an iron block.
The LSX bowtie block is also only 5.500 so far on all the ones we have worked on. It is undercut at the bottoms of the cylinders for honing overtravel and core shift.
Again if you stuck a tape measure down any you will get an incorrect measurement as you aren't measuring the cylinder but rather the casting only.
The older original Darton MIDs are 5.625 long but the newer ones are 5.800 including the dry sleeves.
We installed Weisco pistons that had a ring package that allowed a sliver of the pin bore to protrude past the upper oil scraper. I was told by Weisco that there would be no problem running these. We prepped the cylinder bores very carefully making making oil consumption a high priority. The engine burned a quart every 200 miles. It also filled the catch can. We'll have the engine back this week and take a closer look at it.
Below is a pic of the relationship between the oil ring land and the pin bore. We used a napier second ring in this ring package.
I'd appreciate any comments about this.
Richard
Richard
http://www.proheads.com/webshots/Weisco1a.jpg
Richard
Richard
Richard,
Whats the cylinder bore length and the ring stack and the CH? Thats a huge top land? I've done hundreds of engines with absolutely no problems but I don't have any pistons that look like that although I use Wiseco and Diamonds all the time. Your break point might be outside the bore at the bottom allowing the piston to suck oil past the rings on the intake stroke at BDC when the cylinder pressure is low and the crankcase pressure is higher which it always is on a normal engine. If the pistons are excessively rocking down there the rings may not stay sealed.
