SDPC Announces GMPP's New CNC L92 Assemblies!!
That's right folks! You heard it here first! We've already received a big truck load of GM's new CNC'd L92 heads! Of course, we're offering several different head setups to suit your needs! First, a little bit more about these heads (including flow numbers and pricing)!!!
Specifications
Casting Number 12595364 or 12582716
Valve Angle 15-degree
Combustion Chamber 70cc*
Intake Port Volume 279cc*
Exhaust port Volume 99cc*
Minimum Cylinder Bore 4.000”
* Approximate, Numbers are within +/- 2cc’s
Milling Information for Combustion Chamber Sizing
For 65-cc Chamber Remove 0.030”
Part Numbers & Pricing
SD8699 - $998.98 per pair
-Stock LS1 springs good to .500" lift, stock locks and retainers, 2.165”/1.590” L92 Valves
SD8760 - $1189.95 per pair
-Same as above but with SDL1600VS springs good to .600" lift, stock locks and retainers
SD8765 - $1299.95 per pair
-Same as the first but with SDL1650VS springs good to .650" lift and titanium retainers
SD8800 - $1499.95 per pair
-Same as SD8765 but with Manley Stainless valves
Flow Chart
Flowed @ 28” H20 on a 4.155” Bore
Lift------Intake (cfm)-----Exhaust (cfm)
0.100----69----------------46
0.200----154---------------100
0.300----222---------------136
0.400----266---------------166
0.500----309---------------189
0.600----345---------------202
0.700----358---------------209
Specifications
- Approximately 0.006” per 1-cc
Flow Chart
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
We did not have time to flow an exhaust port yet, these are GM's flow numbers. The intake flow numbers when we got them were very close to these, and we assumed the exhaust would also be in line. We will get a head over and flow the exhaust ASAP.
NOTE: GM's numbers for flow tend to be very conservative.
__________________
These prices do not include rocker arms, pedestals, gaskets, head bolts, etc. They are just the assembled heads.
The .650" lift is a double spring.
__________________
Correct, the intake rocker on the L92 uses an offset rocker. You can re-use your stock exhaust rocker if you would like.
CNC L92 Heads Added To Our Website!
**Edited for Grammar **** Brian Gruben**
**Edited again for Brian, so he'll stop crying about his last name being spelled wrong**
__________________
It says "heads" and "per pair several times in original post.
__________________
There is no bare CNC'd head available yet. I have not heard of any plans to release them bare either.
__________________
It would be the same as the regular L92 heads. We have not milled them farther than about .030" so I cannot say for sure how far you can safely mill them.
__________________
My bare castings I bought from you guys cc'd at 68.5. Factory spec is 68.4 +-1cc. I milled mine .040" and I am now at 62cc. Every head could be a bit different but this is what I came up with on mine. I milled them that far because I am building a LQ4 with the dished pistons. With a .045" gasket I will be at 10.8:1 static CR.
Thanks for the info!
__________________
