Rockers for stock heads
Old 10-20-2007, 11:14 AM
MichaelD's Avatar
Default Rockers for stock heads
I had carteck work there magic on some stock heads, and intake and tb ported. Part of the plan was to use 1.8 ratio z06 rockers, but they dont fit. I want to stay with a stock cam, so who makes a stock style rocker that will fit?
Old 10-20-2007, 06:36 PM
MichaelD's Avatar
I should add that this is for an LS2 powered C6 Vette.
Old 10-20-2007, 06:57 PM
cws T/A's Avatar
Yella Terra ultralight shaft mount , $419 from New Era Performance .
Old 10-20-2007, 07:38 PM
BLK02TA's Avatar
Would these eliminate the sewing machine sound haunted on many ls1's?
Old 10-20-2007, 08:29 PM
MichaelD's Avatar
any more info on these?
How do they campare to stock in weight?
Old 10-20-2007, 08:33 PM
MichaelD's Avatar
As a side note, has anyone tried using the z06 exhaust rockers for the intake.
Old 10-21-2007, 03:39 PM
cws T/A's Avatar
Good info here .
https://ls1tech.com/forums/generation-iii-internal-engine/669911-yella-terra-vs-harland-sharp.html
Theres always the option of having the bearings upgraded in your existing stock rockers .
Old 10-22-2007, 08:06 AM
Mike @ New Era's Avatar
<---Matt @ New Era
We always stock the Yellaterras. They will eliminate the loud valvetrain that some of you speak of. I had the stockers on my 98 T/A, they broke...made a mess, and now I recommend them to anyone with a cam, or to anyone that doesnt want to pick needle bearings from the motor every oil change. They will fit under the stock valve cover, 98 is usually the hardest, they cleared fine. We are also one of the only AUTHORIZED Yellaterra distributors on tech, so make sure you know who you are ordering from.
Old 10-22-2007, 08:17 AM
JMBLOWNWS6's Avatar
TTT For New Era. Mike and Matt are top notch! I buy everything from them!
Joe Michael
