Timing chain and oil pump opinions
Old 10-27-2007, 08:01 PM
RAMPANT's Avatar
Default Timing chain and oil pump opinions
I am building a 455ci LS7 for the Firebird.
I would like to get your opinions on the best double roller LS2 chain.
Also which is the better oil pump, a ported LS6 or a Melling pump?
Are there any issues with any of the pumps or timing chains.
Old 10-28-2007, 04:05 PM
RAMPANT's Avatar
All of these build ups and no one has an opinion or experience to help out?
Old 10-28-2007, 08:35 PM
95FbFormula's Avatar
Mines a little smaller build then your only a 408 but i am going with a tsp ported LS6 pump with a little higher pressure.
Old 10-28-2007, 08:50 PM
shoemike's Avatar
melling won`t clear a dual roller.
get a cloyes single.
Old 11-01-2007, 11:17 AM
cam
cam's Avatar
Dont they use the LS2 single chain in the C5R? I know I have seen posts around when i chose it about that being the case. Cant argue with 24 hrs of redline abuse with the best reliability in the entire series not to mention most amount of wins. Cant beat the price either. As for the oil pump the LS6 feeds many a monster motor on these boards
Old 11-01-2007, 11:32 AM
slt200mph's Avatar
What he said is true..LS2 chain is very strong and the price is right too and has no clearance problems with what ever oil pump you choose...
Old 11-01-2007, 01:57 PM
camarols1's Avatar
The C5R chain is actually made by JWIS, and it is stronger than the GM spec LS2 chain.
Old 11-01-2007, 03:32 PM
Jon @ Speed Inc's Avatar
You can take a little material out like SLP does to make it clear.
Old 11-01-2007, 07:50 PM
1cdub's Avatar
my melling required milling the front cover and near the seal penetration and the front plate on the pump itself. I had to clearance for the double roller as well on the back side. I WOULD NOT GET ANOTHER MELLING LS PUMP...period.
Quick Reply: Timing chain and oil pump opinions
