LS2 stroker cam sensor issue
Ok, car is still down. The tuner told me I had to take the car to a mechanic because he was losing the cam sensor and could not tune it until I got it fixed. The car was backfiring and popping a lot and a few times it would just die. I took it to a guy he recommended because the shop I had it at before was a nightmare. Well, he ordered a new cam sensor for it, put it in, cam code is still coming up. I know he has no idea what to do and is really beating around the bush with the car so I am trying to find out some stuff to pass on to him.
Any idea what could be causing the cam sensor code? Fixes?
Thanks!
Thanks!
LS1TECH & Trucks Sponsor
Yea, those two outer wires on the Katech extension harness are the usual culprit (A and C wires). Once you switch those and clear the codes, it should be all good to go!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Alright, I will give my mechanic a call here in a bit and see if that works. So, I just need to tell him that he needs to switch the a and c wires he should understand what that means...nothing complex about it at all? Thanks a lot guys, I'll update when I figure out what is going on.
