What bearing is this?
I bought a new Lingenfelter 403 and asked to have the pilot bearing installed in the crank. When I went to install the flywheel I found out I didn't have the pilot bearing. Ok, I'll do it myself. No big deal. I called the salesman and told him and they sent one out to me. What I got was GM part 12557583 which is listed in the parts inventory as a clutch flywheel pilot bearing. In my parts manual the part number for the pilot bearing in my crank is 14061685 and is also listed as a clutch flywheel pilot bearing. The pilot bearing I was sent will fit into the end of the crankshaft, but in the outer area, not the inner area that the pilot bearings usually go in.
Is this an LS2 or LS7 pilot bearing? I am going to go and try to find one locally tomorrow because the motor has been in my garage for over a week and I want to get it in. I just want to know what to tell Lingenfelter on Monday morning.
LS1 pilot bearing in crank
Bearing I was sent 12557583
Closeup of the bearing I was sent
Any help would be appreciated.
LSxGuy widda 9sec Mustang
Thats a LS2 Pilot bearing for a C6, I would think the LS7 to be the same. No C5, Fbody or GTO came with that bigger bearing though so unless your motor is actually going in a C6, then you have the wrong bearing.
You can look through the crank sensor hole. If the reluctor wheel looks like 2 plates side by side with longer 1/2" lugs (rotation wise) its the 24x, if it looks like one single plate with about 1/4" lugs its a 58x.
Or if you post up a pic one of us can ID it for you easily.
I kinda pounded on the Pilot Bearing a little bit with a socket and hammer when I installed it about 30K miles ago...
