L92 heads
Old 11-10-2007, 04:31 PM
chrismorales75's Avatar
Default L92 heads
What year blocks can you put L92 heads on and what bore are they made for?
Old 11-10-2007, 04:49 PM
JDP
JDP's Avatar
anything with a 4in bore
Old 11-10-2007, 04:52 PM
cws T/A's Avatar
Default 4.000'' + cylinder bore
Resleeved LS1 , 6.0L Iron , LS2 , L92 , LS7 , LSX blocks will accept the L92/LS3 cylinder heads .
Old 11-10-2007, 07:58 PM
So is L92 the way to go?
What is the least expensive cylinder head setup that flows the most cfm?
I saw that l92 heads ported will flow in the 370 cfm fully assembled for around 1800.00
Are there better heads out there for the price?
Also who makes makes the 6 bolt per cylinder heads because down the road I want to run a LSX block?
Old 11-11-2007, 02:22 AM
jay_lt4's Avatar
My 92 heads cost me $805 total for the heads, rockers, rocker stands
L92 heads bare= $200 each from gm
valves/retainers/keepers=$150 new gm
pac 1218 valve springs=175
8 intake rocker arms, $7 each from gm
2 rocker stands for L92 valve spacing $24
Old 01-02-2008, 03:34 PM
blackcat's Avatar
Where did you get the bare heads for 200 each?
Old 01-02-2008, 04:24 PM
V8Rumble's Avatar
I got bare L92s from Scoggin-Dickey for $175 each (during a 'free shipping' special)...
Old 01-02-2008, 04:29 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Stock GM Heads typically cost:
$380 pr
16x $15 each for Valves $240
Double Spring Kit $275
Total: $900
PRC CNC Ported L92 Heads
$1099 with stock springs
$1349 with prc doubles
For the power gains the prc head is definately worth the little bit of extra $$ over the stock gm castings.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-02-2008, 04:56 PM
V8Rumble's Avatar
IF you have enough cubes to make use of the extra airflow...
Old 01-02-2008, 05:06 PM
LS1TECH Sponsor
Schwanke Engines's Avatar
There are always enough cubes for the airflow, just depends on how fast the pistons can go up and down and stay inside the engine!!!!!!
Old 01-03-2008, 11:57 AM
1970judge's Avatar
L92 heads are a great pickup for something like a stroker engine. On our 403 combo L92's made right under 550 in a 6speed Vette. They flow excellent numbers out of the box, but as mentioned above, make sure your air pump can pump enough for those heads.
-Marcus
Old 01-04-2008, 09:04 PM
bills02raptor's Avatar
So these aren't recommended for a 99 LS1, I am looking for a heads/intake setup for the Vette and have read nothing but good things about the L92's.
Old 01-05-2008, 04:05 PM
slt200mph's Avatar
The bore of your engine is not large enough to use those heads..
Old 01-05-2008, 11:01 PM
WE TODD DID's Avatar
$380 pr
Total: $900
What kind of flow numbers are they getting out of these heads? Do they have a web site?
Old 01-05-2008, 11:24 PM
Hans Grüber's Avatar
$380 pr
Total: $900
Do you think that the GMPP CNC are really worth it? The flow improvement is very minimal.
Also which valves are they? The SUV or light weight LS3?
Old 01-05-2008, 11:34 PM
the_merv's Avatar
Need a 4.000 or larger Bore..you will be bending Valves..
Old 01-05-2008, 11:37 PM
the_merv's Avatar
Here is a pic..these are mine before they went on..
Valves: Stock, 2.16", 1.59"
PRC Gold .660" Lift Dual-Coil Springs
I paid $600 for the Heads, Valves, Offset Rockers, and the Pedistals.
Old 01-06-2008, 12:01 PM
12 Second Truck Club
supersub's Avatar
Here are some WCCH heads with 2.18's int cut into them w/harland prototype rollers
Old 01-06-2008, 10:41 PM
When will those offset rockets be available?
Old 01-07-2008, 07:29 AM
AU N EGL's Avatar
I know I dont have the whole picture, but what is the TQ like from 3000 to 4100 RPMs?
Is something like this going to take off slow, then kick in at 4200 up to 6400 rpms?
TIA
