what do i need
what do i need
my lq9 block is bare, i'm using a eagle crank
what main bearings do i use, i heard stock ones won't work
and for the timing chain just the ls2 timing chain anda ls2 p/n 12588670 dampner?
do i need the dampner?
is cloyes a good timing chain set?
you can use the stock mains, as long as you dont plan on going crazy on power. you just need the ls2 chain, you can use your stock crank pulley. you can get the cloyes if you want, i just used the ls2 on mine since its strong as hell and cheap.
