LS2 Block Value?
You might be able to get 50 out of it if someone is close to you doing an engine swap and they want to use it as a mockup. Other than that... Let me know cuz I have a ls1 with a cracked sleeve.
As long as that is the only problem, it could have great value to someone looking to build a sleeved motor. The same goes for the LS1 if it is a true LS1 block and not the LS6 block. If you find someone looking to send one off for sleeving, it could be worth a couple hundred bucks.
mock up value is all that it is good for-
how much would it be worth if it were good
seen a l92 b/new block go on ebay 2 weeks ago for 550 or 650 us-from bowman motorsports-
the ls2 could not be worth more then that if it were good???
