Crank Reluctor Rings
Old 12-26-2007, 10:52 PM
DoesSpeedTurnUon's Avatar
Default Crank Reluctor Rings
I know there is a difference between the LS1/6 cranks and LS2/3? One has 28(24?) teeth and the other has like 58? Regardless. Were there any truck 6.0's that came with the same ring as a LS1/6 Where you could use a stock shortblock straight from a H2 or Escalade with out taking the crank out?
Possible 6.0's with 24x Reluctors:
05-06 GTO's.
Old 12-27-2007, 10:18 AM
Sawzall and Welder Mod
Whistler's Avatar
All the 99-04 6.0s had the 24 tooth wheel on them.
Old 12-27-2007, 10:23 AM
Excellent, that's just what i needed to know. Any of those would be a direct replacement for an LS1/6 correct?
Old 12-27-2007, 10:31 AM
Whistler's Avatar
One hole needs to be drilled and tapped for the alternator, other than that, yes.
Quick Reply: Crank Reluctor Rings
