What kind of HP?
What kind of HP?
What kind of HP do you think I would get with this setup?
LS2 Block (403ci)
4 inch Callies crank
Compstar rods
Custom JE Pistons
AFR 225 heads
F1A Procharger
17 lbs of boost
23X/24X 113+X
Crane shaft mount rockers
Caddy racing hydraulic lifters
Tony Mamo ported 90mm FAST intake
1 7/8 Kooks headers
3 inch true duals over the axle
9:1 compression
93 octane pump gas
9 inch rear 3.89 gears
Spec twin disk clutch
Exotic Performance Plus front mount intercooler
Alky Control Methanol kit
Koni SA shocks
Sam Strano sway bars
LS2 Block (403ci)
Compstar rods
Custom JE Pistons
AFR 225 heads
F1A Procharger
17 lbs of boost
23X/24X 113+X
1 7/8 Kooks headers
9:1 compression
93 octane pump gas
Koni SA shocks
