Help! oil temperature too high!
Old 01-02-2008, 06:47 PM
Mariner's Avatar
Default Help! oil temperature too high!
I have a problem in my 2006 C6 A6 with the oil temperature. When I'm driving normally it's around 90c to 100c (194F - 212F) but after a race or two it goes up to 115c (239F) last night was a busy night and i had some street action and it reached 127c (260F) !! I'm sure this isn't normal, I'm starting to worry. Anyone had the same problem? Help anyone!
Old 01-02-2008, 09:07 PM
Tbonekilla's Avatar
I've seen 240F with some spirited driving. Oil temp should been higher than coolant temp once warmed up.
Old 01-03-2008, 08:59 AM
LS1TECH Sponsor
mikey's Avatar
Not a problem with a good synthetic oil. If it goes above 280, consider adding an external cooler (standard equipment on our road race cars).
Mikey
Old 01-03-2008, 09:37 AM
XtraCajunSS's Avatar
Mikey is right on the money. I get 240 - 260 in my V routinely. As a matter of fact, you should make sure your oil temp gets into the 220 range frequently to boil off any water based contaminants...
Shane
Old 01-03-2008, 10:45 AM
chromeplated500's Avatar
does high oil temp ever hurt anything? i guess ive never heard much either way on this.
Old 01-03-2008, 11:45 AM
Kleeborp the Moderator™
MeentSS02's Avatar
If you run a crappy oil, it will start breaking down. A good synthetic oil should be able to handle that no problem...
Old 01-03-2008, 03:07 PM
Mariner's Avatar
Shane
Is there any harm if the oil temperature is high (around 212 to 220) most of the time? and does it affect the car's performance?
Mikey
Is there a cooler designed specially to cool the oil temperature? And is it easy to install? Where can i find it?
Old 01-03-2008, 03:09 PM
MeentSS02's Avatar
There are all sorts of options for cooling the oil...just search "oil cooler" and go from there (Jegs and Summit carry them, along with lots of other places). Ease of install depends on your definition of ease of install...you'll have to use an adapter of some sort, and run the extra lines necessary.
A good source for this information is frrax.com. Those guys use oil coolers all the time...
Old 01-03-2008, 04:08 PM
Mariner's Avatar
And does the c5 oil cooler fit on my C6 A6 ?
Old 01-06-2008, 10:46 PM
DONAIMIAN's Avatar
As of right now I wouldn't worry about your oil temps. your 212-220 is normal. A good synthetic can handle 300.
Old 01-07-2008, 07:33 AM
AU N EGL's Avatar
239 is not a problem. 250-260 is what is recommended for max safe temp.
Yes the Oil can take low 300s and internal moving parts upper 200s for short periods of time. Oil even a great synthetic degrades at high temps.
Old 01-11-2008, 10:07 AM
Mariner's Avatar
I guess i shouldn't worry then.
Thanks guys, appreciate your help.
Quick Reply: Help! oil temperature too high!
