Where to buy quality 402/403 stroker kit/rotating assembly?
Old 01-12-2008, 07:43 PM
Zturd's Avatar
Default Where to buy quality 402/403 stroker kit/rotating assembly?
I'm balancing and budgeting a possible engine build up for my C5. I am looking more towards a 402ci engine. I like the quality of Compstar/Callies cranks,rods. I've looked through almost all the LS1tech sponsors and not seeing anyone thats offering stroker kits including things like (crank,rods,pistons,bearings,rings etc etc). Could someone please direct me to where I can price some items of putting in a LS2 block.
OR
Is it better to take the stock LS2 short block and make some kind of build with it? My head is just spinning at this point.
Looking for end result to be a streetable car with 500rwhp good torque #'s but not break the bank. I'm not looking for a $5000 engine. I will most likely have to put my Stage1 TSP PRC LS6 heads/Fast 90/90 ported on the short block for now till I can afford a better set of heads. I want a compression ratio no higher then 11.5:1 approx. Run on pump gas premium. Possibly put small 150shot of nitrous to it.
Old 01-12-2008, 08:30 PM
Shawn @ VA Speed's Avatar
I can get you whatever you need-pm me with exactly what you want,and i get you a price
Old 01-13-2008, 08:08 AM
2000PewterZ28's Avatar
Call TSP, they will help you get what you need.
Old 01-13-2008, 09:15 AM
Deeavi's Avatar
I got my Compstar kit from Speed, Inc.
Old 01-13-2008, 10:04 AM
Zturd's Avatar
Thanks Deeavi.... They had exactly what I was interested in for $2449.00 for everything to go in a short block it seems.
The next question that would have to come to mind is how much does machine work typically cost to turn a LS2 short block into a 403 stroker and put this kit in??????
Old 01-13-2008, 11:40 AM
ramairroughneck's Avatar
Scroggins-Dickey has a ad in this months magazines for 402/416ci rotating assymblies with manley pistons, compstar rods & crank, clevite bearings, and A&C Race Rings for $1800. LS2 block for $1000 and $L92 block for $1400. I too have wodered what the additional cost for machining and assymbly would come to.
Old 01-13-2008, 12:51 PM
Red99C5's Avatar
Where can I find this ad at?
Old 01-13-2008, 02:29 PM
March Chevy High Performance Pg 39
March GM High-Tech Performance Pg 11
http://www.sdparts.com/
1-800-456-0211
Old 01-13-2008, 03:58 PM
Red99C5's Avatar
Thanks, I guess I need to go and buy a Mag.. I already looked on there website. I only see the Lunati rotating assembly.
Old 01-13-2008, 04:28 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Old 01-13-2008, 06:20 PM
V8Rumble's Avatar
Heh - that IS kinda funny...
Old 01-13-2008, 06:54 PM
Red99C5's Avatar
Originally Posted by Beaflag VonRathburg
For $1800???
Old 01-14-2008, 10:21 AM
WeberRacingEquipment's Avatar
We have out K1 Tech./ Wiseco Rotating Assemblies on sale for $2075. This is includes balancing. Here is a link to our web page: http://weberracing.net/Engine-Type-G...184/index.html
Old 01-14-2008, 07:58 PM
Zturd's Avatar
While i have some peoples attention another question came to mind. I seen the valley cover of the LS2 and it had what looks like a formed in pipe coming up out of the back of it? I thought they were flat the entire way back???
Old 01-15-2008, 08:04 AM
If you are talking about the pipe on the rear drivers side that sticks up behind the intake. That is for the oil pressure sender.
Old 01-15-2008, 11:53 AM
Jon@Texas-Speed's Avatar
PM Sent!
We can get you set up with a rotating assebly to meet and exceed what you are looking to do. We offer a full line of Callies bottom-end components including both Compstar and Dragonslayer product lines. We also offer Texas Speed exclusive pistons from Diamond Racing. These pistons are made from the 2618 forging to ensure they will take a great deal of abuse. Each rotating assembly comes with a Total Seal Ringset with a Napier second ring to help with oil control and Clevite bearings. We can also have the rotating assembly balance prior to shipping as well so you will just need to block work taken care of and assembly.
You might also take a look at our stroker short-blocks. We have over 40 on the shelf and ready to ship. The same top-of-the-line, name brand components are in every stroker we build. You won't find inferior parts in our motors to save a buck. Every motor is balanced and blueprinted as well!
PM or give me a call if you have any questions or concerns and we will get you fixed up right away.
Thanks!
Jon Reynolds
Old 01-17-2008, 09:52 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
John's right we have probably 40 short-blocks instock & just about every component to complete your rotating assembly! Let us know what you need & we can get it out of here most likely same-day!
Old 01-18-2008, 12:59 PM
Zturd's Avatar
Man I have to first say thanks to all the people from the shops that took the time to PM/reply to me and help in this hunt!!! This is why I am looking from something from here I want to deal with a site sponsor and purchase with confidence/knowledge. So THANK YOU all and I"m still gathering info and not ready to pull the trigger. So anyone thats done the swap and can shed some light on things I should get or keep etc would be helpful.
Bruce
Old 06-02-2008, 10:03 PM
CBIII's Avatar
im interested in what youve heard also. my lq4 is shot and I need something new. Id rather find a budget shortblock but would consider a rotating assembly or stroker kit. Im looking for around 500rwhp out of it.
Anyone want to shoot me some prices?
Old 10-06-2008, 02:54 PM
Spectre86's Avatar
bump for nice info, did anyone give you a rought guess on machine shop work pricing on what had to be done? Im lookin at picking up either a ls1 or ls2 block for a winter build and trying to see what is out there
Quick Reply: Where to buy quality 402/403 stroker kit/rotating assembly?
