LS7 swap
LS7 swap
I have a ls7 block, eagle 4.0 crank, ls7 clutch going into a car fitted with a 2002 camaro t56, with 2002 camaro TOB.
I want to check on a couple of things. I have just read that there are a couple of throw out bearing differences between some of the t56.
I have the trans in the car, but the engine is with the builders, so i cant check dimensions and work out any clearances myself until the engine is shipped...so
Can you tell me what i need to check to make sure that i have a tob that will work with the crank and clutch, or if there are any other issues I need to watch for.
The engine is being shipped form US to UK, so I want to make sure i get everything checked before it gets shipped over
I am trawling through some info on the site, but have not found yet what i need
