15 degree heads on 11 degree pistons, will it work?
Old 02-06-2008, 03:01 PM
xxxhp's Avatar
Default 15 degree heads on 11 degree pistons, will it work?
Iam planning to jump on this deal for a friend of mine https://ls1tech.com/forums/lsx-parts-sale/859088-449ci-ls2-shortblock.html
However, my friend is on a tight budget and therefore he would like to use a set of used ported LS6 heads (4.125 bore) on this engine temporarily. The cam we're planning to use is COMP XE-R 244-244 .612-.612 114 LSA.
What do you guys think?
Old 02-06-2008, 06:06 PM
ExTurbo's Avatar
they should fit depending on if and how much the heads are milled. I've definately be checking PTV either way.
Quick Reply: 15 degree heads on 11 degree pistons, will it work?
