Vendors, shops, and customers... who has got the L92 to start cranking like it should
Old 02-14-2008, 10:48 PM
Johny GTO's Avatar
Default Vendors, shops, and customers... who has got the L92 to start cranking like it should
I see some people having trouble with the L92 heads, not getting impressive numbers. Yet others i see getting some sick numbers like Rick at Synergy. Anone else had big numbers and area under the curve with the L92's?
Vendors and shops in particular. Who is balling with these heads, and do u have any packages?
Old 02-15-2008, 12:41 AM
Tom@SpeedInc's Avatar
we put a set of our L92 prepped heads on 8.5:1 SCR 408 with twin PT61 turbochargers; 921 rwhp at 18psi
http://www.flickr.com/photos/speedin...7603177604521/
that enough power for ya?
Old 02-15-2008, 12:45 AM
Johny GTO's Avatar
lol. i would say so.
i was looking for NA LS2 motors though. sorry, should have been more clear.
that s damn impressive though, good work.
Old 02-15-2008, 05:41 AM
WKMCD's Avatar
These numbers are on a very stingy dyno and as driven on the street. No dyno tricks here. I'm not sure that this meets your "cranking like it should" but it's a great overall street drive. Power everywhere makes it drive like a BIG electric motor.
Old 02-16-2008, 07:47 PM
1997bird's Avatar
Not only that, but a very repeatable dyno!!
Old 02-18-2008, 09:48 PM
GTbrunO's Avatar
More details please?
Old 02-19-2008, 05:49 AM
WKMCD's Avatar
It's all here.
https://ls1tech.com/forums/generation-iv-internal-engine/662314-l92-dynojet-numbers-plus-plan-b-c-d-e-f.html
Old 02-19-2008, 05:53 AM
studderin's Avatar
local friend thats not on heres car. SOM
http://www.neweraperformanceparts.co...m)&NID=4434442
http://www.neweraperformanceparts.co...buildsS005.jpg
Dan's 01 SS has an LME built 402 shortblock with unported L92 heads , New Era custom cam , LT headers and magnaflow exhaust with a qtp cutout . Dans SS made 505 rwhp and 477 rwtq tuned by Mike @ New Era .
Old 02-19-2008, 12:04 PM
Johny GTO's Avatar
Do the L92 heads perform much better with camshafts designed specifically for those heads? From the reading i have done, it seems the valve events need to be altered due to the huge intake port on those heads. Using a camshaft meants for traditional cathedral port heads (5.3, ls6, 6.0 heads, trickflow, patriots, etc) leaves alot on the table from what i have read (and seen in peoples results).
It seems you can get good results with these heads and aftermarket cams, but to really make these heads perform the cam has to be made for these heads.
Can some of the cam guys chime in here?
What about you sponsors and shop techs? What have you found?
Old 02-19-2008, 12:05 PM
Johny GTO's Avatar
that is sexy as hell. But it is on a 402ci, correct? I am rocking a 6.0
Old 02-19-2008, 12:13 PM
edcmat-l1's Avatar
Below, 6.0 GTO with less than optimal cam.
We have a 403 L92 going together right now. Dyno results coming in late March, after we get the motor over to Germany and in the car.
We'll be using a Superflo chassis dyno, so the results should be similar to Dynojet.
Old 02-19-2008, 12:44 PM
Johny GTO's Avatar
that is rather nice. That dyno is of a stock cube gto, correct? what esle was done to it (long tubes, intake, fast, etc)?
Old 02-19-2008, 12:53 PM
edcmat-l1's Avatar
Long tubes, ported intake, stock cubes, cam, L92s, UD pulley I think. Nothing special really.
Just good use of whats there.
Old 02-19-2008, 01:11 PM
Johny GTO's Avatar
that is sweet. Are the cam spcs secret? Do u have a head\cam\ported intake package?
Old 02-19-2008, 01:16 PM
edcmat-l1's Avatar
We're coming out with our own H/C/I package very soon. We have several things in the works right now.
Cam specs arent secret, but ours will be.
Quick Reply: Vendors, shops, and customers... who has got the L92 to start cranking like it should
