What compression is an LS7 440 Stroker with 76cc heads?
Old 02-17-2008, 08:40 PM
Piersin's Avatar
Default What compression is an LS7 440 Stroker with 76cc heads?
LS7 Stroker 440 with 76cc heads, what compression?
Old 02-17-2008, 08:51 PM
RAMPANT's Avatar
You need a little more info.
bore
stroke
piston dome volume
piston deck height
volume above the compression ring
gasket bore
gasket thickness
Old 02-17-2008, 09:11 PM
Tom@SpeedInc's Avatar
who has 76cc heads?
Old 02-17-2008, 09:17 PM
Piersin's Avatar
bore
stroke
piston dome volume
piston deck height
gasket bore
gasket thickness
bore 4.125 bore and 4.1 stroke
stroke 4.1"
piston dome volume Flat top Standard Weisco
piston deck height Standard deck height
volume above the compression ring Standard
gasket bore GM
gasket thickness GM
I'm lacking all the details but a ballpark would be cool.
Flat top
Don't know the deck height. What is industry standard?
Old 02-17-2008, 09:45 PM
Greg Fell's Avatar
http://www.c5frc.com/calculators/Com...Calculator.htm
also, most any piston will be at least -2 cc for valve reliefs
Quick Reply: What compression is an LS7 440 Stroker with 76cc heads?
