ls2
Old 02-18-2008, 11:33 AM
2002t/a06's Avatar
Default ls2
im swapping a forged ls2 longblock in my car and i know that a few things are different. ive heard the knock sensor, crank sensor are in a different location. is this true?
Old 02-18-2008, 04:09 PM
bottlefed01z28's Avatar
Old 02-18-2008, 04:16 PM
2002t/a06's Avatar
umm i already tried a search....
Old 02-18-2008, 04:28 PM
Greg Fell's Avatar
knock sensors, cam sensor. not sure about crank
Old 02-18-2008, 04:43 PM
2002t/a06's Avatar
thanks.
Old 02-18-2008, 05:15 PM
HSV-GTS-300's Avatar
LS2 knock sensors are on the side of the block down near the pan rail, same on both sides. The stock LS2 bosses are female threaded M8, open out to M10 and fit LS1 sensors in there.
LS2 cam sensor is in the front timing cover.
LS2 crank sensor is in the same spot as LS1. If you are running an LS1 computer you'll need a black crank sensor and a 24x reluctor wheel fitted to the crank.
Old 02-18-2008, 05:40 PM
2002t/a06's Avatar
thanks a lot hsv-gts-300!
Old 02-18-2008, 05:41 PM
wg871's Avatar
good thread-helpful!
Old 02-18-2008, 05:43 PM
2002t/a06's Avatar
yes, very helpful
Old 02-19-2008, 08:15 AM
rpmauto's Avatar
question on the timing chain?? That black part between the gears is a chain damper do you need that when you use a double row chain?? i bought my shortblock used, and it did not come with one of those. Do i need it?? Sorry to hijack.
Old 02-19-2008, 02:33 PM
ringram's Avatar
Almost sticky material with all those nice pic's
Old 06-15-2008, 08:48 AM
TheLS1Kid's Avatar
I have a question about this pic, I understand where it says "normal" in red means that is where you tap for the knock sensor, Where is the other hole to tap for the 2nd knock sensor? Does "alternate" mean you just choose one of those in addition to the "normal" red hole? I assume it doesn't matter that the sensors would be at an angle to eachother. Thanks guys. Sorry if that is hard to understand.
Old 06-15-2008, 04:01 PM
Walk around to the other side of the block (not pictured) and you'll find another M8 LS2 knock sensor boss to tap there...mid block down near the pan rail. Sorry I thought "SAME BOTH SIDES" might have covered that.
Alternate location is usually too close to headers but is a get out of jail fix only for people who forget to tap out the holes before installing the engine.
Old 06-15-2008, 09:08 PM
TheLS1Kid's Avatar
Thanks for clearing that up. Just so I know for sure, on the new block I need to tap it so there will be one sensor on each side of the block correct?
Old 06-15-2008, 09:12 PM
Yes
Old 06-15-2008, 10:06 PM
TheLS1Kid's Avatar
Appreciate the help.
Old 06-24-2008, 10:16 AM
VGLNTE1's Avatar
subscribed
Old 10-20-2008, 10:09 AM
Big Bird WS6's Avatar
[QUOTE=HSV-GTS-300;8738190]LS2 knock sensors are on the side of the block down near the pan rail, same on both sides. The stock LS2 bosses are female threaded M8, open out to M10 and fit LS1 sensors in there.
question about the knock hole. if i us the alternet location. which one of those six hols is used for the motor mounts.
Old 10-22-2008, 09:45 AM
WADDISME's Avatar
Hey, I resemble that remark.
Old 12-05-2008, 01:17 PM
camarorat's Avatar
can you use the LS2 8mm style knock sensors on a ls1 car, do they have the same plug, will they work with the ls1 PCM; or do you have to use the bigger ls1 style knock sensors?
Quick Reply: ls2
