How to run cam sensor extension harness?
On my 98 the sensor wire harnes includes the knock sensor connectors. It splits at the back of the engine. The passenger side knock sensor goes over my starter and connects to the knock sensor in that side of the block.
The cam sensor wire and the drivers side knock sensor wire go down the the drivers side of the block, then tied to the oil filter block off plate above the filter. the knock sensor is connected and then the cam sensor wire runs down the pan rail. I have both wires wrapped in aluminum tape to shield them from heat.
Two of the cam sensor wires had to be reversed for the cam sensor to function properly.
Yes. Follow the passenger side injector harness to the front of the engine, down to the bottom and across to the cam sensor. Make sure to use straps to hold it in place away from moving parts. Mine is tied to the k-member.
