Spun bearing...ls1 thrashed... Need shortblock advice
Ok, so here is the story. After installing all mods in my sig (except for headers/exhaust/lid) the car dynoed 435 first pull, no tune. Next pull, after 5000rpm heard clanking. Shut her down, pulled oil filter and worse case scenario (metal shavings). Shop thinks its a spun bearing, so that means I need a new shortblock. I want to keep the upper portion of my motor (H/I), but know i will need another cam. Was thinking either
1) 402 ls2
2) 418 ls3
What should i do. Are there any advantages in going with the ls2 over the larger bore ls3/lq9? The car will see a healthy dose of N2O (300 shot), so it needs to be forged regardless. Am looking to buy at the end of next week, but i need the block to be shipped relatively quickly.
Also, I don't know what all is needed for the ls2 or ls3 swap. Does anyone sell a basic kit for this?? I have seen a few threads, but i am getting tired of ordering parts from 60 different vendors.
1) 402 ls2
2) 418 ls3
go with the ls3 block,cost about the same money and you get a bigger bore,bothe will handle same power,you need to change the frt rear and valley covers,relocate knock sensors and extend some wiring,
So aside from the block itself, all i need is the front and rear valley covers. In addition I will need to relocate the knock sensors, and extend some wiring? I thought there was more to it than that. Good to know.
I do know the LS3 has a higher displacement and has been shown to respond very well to mods. If it were me, I would go with the LS3 stroker vs. LS2 given the two choices.
What are your goals? Daily Driver or Race Car?
Well, it is supposed to be my DD, but I am looking at possibly acquiring a beater for DD. regardless I wan't the car to be reliable. I don't know what to do now. I might just have the motor rebuilt.
The AFR heads he has are made to adapt to a 3.9" bore? If so, is it okay to run with a 4.060" bore? or whatever the LS3 bore is? because I was told its not the best idea to run with larger than a 4" bore.... but if its okay to run with a larger than 4" bore, then I may just do a 418...
if the LS3 bore isnt bigger than a 4" and if the AFR heads he has are bigger than for a 3.9" bore, then disregaurd this....
You need to pay close attention to your CR with those AFR 205s (62cc) heads. You will be close to 12.0 CR with flat top pistons on a 402ci.
Better not go more that 4.0" bore (402LS2) on those heads.
