Patriot stage 3 heads , with speed inc SI5 camshaft
Ok i have a Ls2 6.0 364cid engine. with 4.005 bore and stock crank with scat i beam rods with 8720 ARPp rod bolts, and 4.005 bored Diamond forged Pistons with stock valve reliefs in the pistons , now im getting Stage 3 heads with 64cc, 2.08 intake and 1.60 exhaust, with speed inc SI5 camshaft , cam specs are as followed 231/237, .589/595 lift at 112lsa , will i have any problems with piston to valve clearance ?
Im going to try the whole thing with hobby play doe to put on top of the intake and exhaust valves on the pistons then put the whole heads and everything else together and check to see how much my clearance is !! should be around .080 clearance on the intake , and .100 on the exhaust right ?
