Warhawk block and LSX block the 2 bolt hole for head are different spots where
Old 03-15-2008, 02:58 PM
BigRich954RR's Avatar
Default Warhawk block and LSX block the 2 bolt hole for head are different spots where
The 2 extra bolt hole are in diff places on the two blocks so you can only use the warhawk head with the warhawk block. What make them different.
Old 03-16-2008, 02:36 AM
Jeff@TotalPerformanceEng's Avatar
All of Warhawks stuff is propriatary..(You have to buy THEIR stuff) The LSx stuff works with pretty much everything designed for the LS based motor.
Old 03-16-2008, 10:36 AM
Why would they do that. Looks like im just going to weld tabs on the ls2 block for the 2 bolts
Old 03-18-2008, 03:53 PM
Cstraub's Avatar
Morel makes the hyd roller roller lifter for this block, it is currently available. . .tie bar style only.
Old 03-18-2008, 08:21 PM
89rsragtop's Avatar
World was first you should ask GM.
Old 03-18-2008, 10:35 PM
LS1Tech Sponsor
Robin L's Avatar
We have been down this road before. Warren Johnson and the GM Performance Parts engineers designed what they felt was the best in their opinion. Not taking away anything from anyone else but they are entitled to build it the way they see fit.
I think that ET offers heads with either bolt pattern.
Robin
Old 03-20-2008, 11:25 PM
deviant1's Avatar
out of the 2 blocks which one would be best to use in a twin turbo situation with roughly 750-1000 rwhp
Old 03-21-2008, 12:24 AM
oscareltemblo's Avatar
I would go with the lsx.
Old 03-21-2008, 07:42 AM
LS1Tech Sponsor
Robin L's Avatar
Either block is capable of that goal.
There are benifits to each product. It comes down to what you want.
Robin
Old 09-23-2008, 11:42 AM
Yeajimi's Avatar
The World LS7X heads can be bolted in a 6 head bolt configuration on either the Warhawk block or the Gm LSX block.
I'm sure each block can easily get you to your power goal. The question is how will pricing affect your decision and would you prefer aluminum or iron?
Old 09-23-2008, 10:06 PM
KCS
Moderator
KCS's Avatar
Depends on your budget really. I would go with the LSX because of the price, durability, and compatibility.
IMO, the Warhawk is more like a showpiece rather than a practical foundation for an engine build. Compared to the LSX, you really are only losing weight both in the block and in your wallet.
Old 09-24-2008, 02:06 AM
Tom@SpeedInc's Avatar
The Warhawk heads can be bolted to an GMPP LSX block and the outter extra head bolts can be used, just lines up
LSX heads can be bolted to a warhawk block, the outter stud holes can be used, but the LSX outter hardware is smaller dia. the warhawk uses larger outter studs.
you will have to enlarge the outter head bolt holes about 1/8" and you can use the warhawk hardware to have, this gives you 5 bolt setup. Alot of the larger heads come standard LSX pattern now, thats how I found this out.
ET ran 5 bolt on their warhawk setup in Cary car?
Old 09-24-2008, 07:42 AM
HUNTER02SS's Avatar
For that power range,just use a 6ltr. iron block?
Old 09-24-2008, 08:27 AM
TTPMatt's Avatar
We are using the Warhawk block with their LS7X heads on my race car. We have not fired it yet. The block is beautiful but does require some extra work to get all the bolts down to size to fit, etc.
Quick Reply: Warhawk block and LSX block the 2 bolt hole for head are different spots where
