6.100 Scat rods for stock LS2 with SCAT 6125 Stamped on the side of the rod
Ok i got Scat I beam rods with ARP 8720 Bolts , can these bolts be torqued down more then once ? at 64lb ? or should i replace them even thought the engine hasnt been run ? i just have to double check somthing so i had to torque them down again is this ok ?
I got Scat I Beam rods from Speed inc They say they are 6.100 rods , but stamped in the side of the Rod SAys SCAT6125 they say this is just a stamping # , has anyone heard about this ?
about Scat rods ?
has anyone else heard about this ? im thinkinking i got 6125 rods cause it seems to be sticking above the deck just a little , but they say they are 6.100 rods , so im totally confused
I did a search for You, hope this reduces the confusion. This is a copy and paste from wwwbrandx .com(not a real url)
2-LS1-6100-2100-927 6.100", 2.100" Pin, ARP 8740 Bolts BUSHED $385 $459
2-LS1-6100-2100-945 6.100", 2.100" Pin, ARP 8740 Bolts BUSHED $385 $459
2-350-6125-2100 6.125", 2.100" Pin, ARP 8740 Bolts BUSHED $385
Sure looks as if You have 6.125 rods, do You have a caliper? You could measure them to be sure.
Carl
Carl
If that is who You are dealing with then I would believe they are 6.100, He has a pretty good reputation on here.
You should measure to see how proud the pistons are so You will know what gasket to use.
Carl
Carl
