quick connecting rod question...opinions needed ASAP
ok.....dilema:
should i splurge on new forged H-beams, or if i could pick up a set of GOOD used titanium LS7 rod, should i get them instead for less than the cost of new Compstar (for instance) H-beams?
exactly how much are LS7 rods meant to handle? they would be going in a 11.5:1-ish NA LSX. shooting for 580-620rwhp...ballpark. MAYBE putting a 150-shot on much later down the road...
thoughts?
thanks,
ben
thoughts?
thanks,
ben
Beat me to it. Get the h-beams for sure. Remember the what and why behind the engineering on the LS7. Its the first of this platform with 4" stroke from the factory and able to spin 7K rpms. They did it for rotating mass reasons. The Ti. alloy they used is also cheaper than aerospace and typical high grade Ti. alloys.
yeah....i knew it wasn't the optimum choice for rods, BUT...you gotta think, there are C6 Z06's out the running stock bottom ends making huge power to ground. if i built the motor i have in mind, it'd be in the 650/600 range at the flywheel. is that too much for GM Ti rods?
OWN3D BY MY PROF!
OWN3D BY MY PROF!
Think of titanium as light all you want. But dont think of it as a fix for a high hp build. Be it 600, 800, whatever. Spend what I thought was about the same money, or just get a set of eagle rods. I wont lie, but as understand from others experiences, I would personally run entry level eagle rods over what you are presenting. The only up side would be a lighter assembly, and unless you are spinning a solid setup to 8K+ rpm, it doesnt really matter. Be safe and run a normal setup thats proven. Dont let some "neat" rod be the part thats takes out a nice shortblock.
There are everyday benefits to running a lighter rotating assembly though. You'll produce less wear and tear on the engine and it'll rev faster than a similar setup with the only difference being a set of steel rods. Like I said before the LS7 rods can be beefed up majorly, but largely they are untested at high HP applications. That and by the time you've had them beefed up they'll probably cost more than a really top of the line set of billet steel rods. There aren't too many people running them ***** out every day for years at a time like there are people with forged steel rods.
For 600 flywheel hp I'd run the LS7 rods with good rod bolts. If you ever plan on doing anything more than that though I'd really reconsider your choice.
i was interested in them for their weight properties, and i really don't think the car would actually see a bottle, it's just a possibility. the only real reason i asked is because there's a set at a dealership that were taken out of a totaled Z06 with under 10K on it that an old man bought for his wife. they're in great shape, and i dunno what Katech charges to put bushings in, but i figured i'd have a decent set of rods for the cost of steel H-beams, and 200-300 grams lighter.
it's just a thought, i'm leaning towards a Compstar assembly
LS1TECH Sponsor
Z06 Titanium rods
I am shortly putting together a 454 short block assembly for a Tech member using the GM Z06 rods. Katech bushings were already in the rods when I received them. The stock bolts leave much to be desired. Replace with ARP bolts. This is not a simple bolt replacement. The rods must be chamfered or the ARP bolt head will seat on the chamfer due to the larger shank diameter. This is easy to miss. Also the rods must be resized. They close up close to .002" with the better bolts.
Steve
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Steve Demirjian
Oceanside, Ca.
760-630-0450
Steve
Steve
i hate it when there's never a definitive yes or no answer. i'll always wonder "what if" if i don't use the rods, but it's better to take the safe way out and imagine how much the sight of a Ti rod sticking through the side of my block would suck
1 Post
What we need to do here is band together and convince Howards Racing Components to offer a powder forged 6.098 and 6.125 rod for the LSX family. The ones they offer for gen 1 & 2 SBC's are badass. 4620 chomoly forged sintered metal rods rated for 800 hp with only 585g recip. weight for 680.00 and they're US made ......sweet!
It would be a great affordable alternative to these chinese **** rods.
