New pistons should i re balance?
Hi Guys, i moving to a 4.070 bore block and fitting my existing 4" crank into it.
I am fitting Mahle pistons to my Eagle assembly, would you guys reckon to balance it up? Cheers
weigh the pistons, rings, spacer and pin of both pistons sets that will tell you what you need to do
if your within a few grams you can get a heavier pin, if your going to a heavier piston may not be an option.
